KeeneticOS 5: smarter, simpler, and more in control
KeeneticOS is more than firmware — it’s the system that powers how your network works every day. It turns a router into a flexible, reliable platform you can easily control and adapt to your needs.
With KeeneticOS 5, this experience becomes even simpler, more automated, and more powerful — without adding complexity.
A network that sets itself up
Getting online should be effortless.
With KeeneticOS 5, your router can automatically detect your connection and apply the right settings. This reduces setup time and helps you avoid configuration errors — whether you’re installing a single device or managing multiple networks.
You spend less time configuring and more time connected.
Give access without giving up control
Not every user needs full admin access.
The new Manager role lets you safely delegate tasks like Wi-Fi management or guest access, while keeping critical settings protected.
This makes it easier to share control — at home, in the office, or across multiple locations — without compromising security.
Secure access, made simple
KeeneticOS 5 includes built-in WireGuard VPN, so you can create secure connections in just a few steps.
You can quickly set up remote access to your home or office network, generate configurations, and connect from your devices with ease.
Fast, modern, and secure — without complicated setup.
Smarter traffic control
Your network should work the way you want.
With DNS-based routing, you can define how traffic is handled based on domains, not just IP addresses. This gives you more flexibility to:
• manage traffic across different connections
• apply policies to specific services
• simplify complex routing scenarios
You stay in control, without needing advanced configuration.
More control over apps and devices
Your network should adapt to how you use it.
KeeneticOS 5 gives you more control over applications, devices, and user access. You can define how different types of traffic are handled, set policies for specific devices, and manage access with greater precision.
This helps you:
• prioritize important traffic
• limit or control specific services
• create a more secure and predictable network environment
Everything works in a clear and manageable way — without unnecessary complexity.
Always connected
Your network should stay online — even when your main connection doesn’t.
KeeneticOS 5 makes this easier with improved mobile connectivity and built-in eSIM support. You can add and manage mobile profiles directly in the interface, switch between operators, and use mobile internet as a backup connection.
If your primary connection is interrupted, the system can automatically switch to mobile — keeping your network running without manual intervention.
Reliable connectivity, built to adapt to real-world conditions.
Clear visibility and better diagnostics
Understanding your network shouldn’t be complicated.
With an updated interface and built-in tools like iPerf3, you can monitor performance, test speeds, and quickly identify issues.
Everything you need is accessible and easy to use.
Built to grow with you
KeeneticOS 5 is designed not only for today’s needs, but for what comes next.
It combines automation, flexibility, and control in a way that works for both home users and professional environments. Whether you’re managing a single network or many, the system adapts to your setup.
The result
With KeeneticOS 5, your network becomes:
• easier to set up
• simpler to manage
• more reliable in everyday use
And most importantly — it gives you the control and confidence to use your network exactly the way you need.
Learn more about KeeneticOS 5 and explore all features on the official page.
